show cfm segment frame-loss statistics {segment-name}
Displays shows frame-loss statistics.
segment_name |
An alpha numeric string identifying the segment name. |
N/A.
The below output is an example for displaying the frame-loss stats for the cfm segments. This command shows the recent, minimum, maximum and average near-end and far-end frame loss ratios during the current transmission. The stats for a particular segment will be preserved till the user triggers the next LMM transmission or until it does a clear counter.
The following command displays the frame loss statistics for the CFM segment:
LEFT.93 # show cfm segment frame-loss statistics
Segment Name MEP Last Last Min Max Min Max Mean Mean
ID NE FE NE NE FE FE NE FE
FLR FLRFLRFLRFLRFLRFLR NLR
seg1 111 10 10 10 10 10 10 10 10
seg1 222 10 10 10 10 10 10 10 10
seg2 333 10 10 10 10 10 10 10 10
Legend: FE - Far End, NE - Near End, FLR - Frame Loss Ratio
Window FE FLR Last FE Tx Last FE Rx
cs2 3 0.000000e+00 509467221 526672689
0.000000e+00 501936465 544907407
This command was first available in ExtremeXOS 15.1.
